Terminated the instrument panel power and ground leads. Added more jumpers between the breakers and switches. Terminated several of the wires from forward of the firewall to the panel. Started wiring the CHT probes to the Westach quad switch and gauge.
Made a trip to Radio Shack to pickup a power connector for the AV80R gps (RS 274-1532). This needs to be modified into a right angle connector to fit the AirGizmos mount.
Ordered some 16 pin Namz Molex MX 150 connectors to connect the EGT/CHT probes to the quad switch.
Ordered a USB to DB9 connector from Bendix-King/Honeywell (005-03702-1017) to connect the AV80R to the DigiTrak autopilot control. I may need to add a hole in the left side mounting bracket of the AirGizmo to fit the USB cable in if it does not bend easily. The AV8OR will feed position and waypoint data to the DigiTrak.
